x
profile.country.en_IE.title
claredude
Visitor
Sony MP3 NWZS544B
Can I charge this mp3 player from mains?
Instructions say from computer, but does not say I cannot charge from mains.
Would appreciate any hep
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.en_GB.title
Drumzman
New
I use a Sony mains USB charger for Walkman - I connect the dedicated USB lead that comes with the Walkman to the USB charger - and this works well.  I don't see any reason why a universal USB charger wouldn't work if you can't find one of the Sony ones.
Hope this helps.
2 REPLIES 2
Drumzman
New
Hope this helps.
claredude
Visitor
Hello Drumzman
Thanks for the advice...I will get one
This is a great help
