Got my new Sony WF-1000XM3 and went to download the Sony Connect App and for some reason, it no longer shows up in the AppStore and when I try to use Google to go to the AppStore it says it's not available in my region when it showed up a few days before. Any help?
Hi SyedN2000,
We're aware of this issue and investigation has already been started.
Thanks a lot for your response. Sorry to ask, but do you have a timeframe for when it will be fixed?
Same issue here. Tried to update my app on the App Store and was told that it is no longer available.
Same issue here!
Do you have any timeframe when you'll have that issue resolved?
I am facing the same issue. Very strange
Item unavailable on the UK Play store.
Hello everyone,
Unfortunately I don't have an exact time frame.
But I have been told that the app should be back in stores shortly.
i have just today bought sony wf-1000xm3 headphones and it says the sony headphones connect app is not available in my country whats going on
should i return my headphones they seem useless
