Hello ,Does anyone have technical information about the Radio compact antenna an 71
@cosmingpx8 What I have found so far is the antenna length: Approximately 5 meters, and This antenna is ideal for enhancing LW/MW/KW reception and comes with an integrated cable.
Abath this antenna tehnical informatiom
Thx Sow Much
