I am having trouble deleting stuff I have finished with of my sony walkman, any help greatly appreciated
Thanks Jim
Hi Jim,
Which Sony Walkman model do you have?
It does depend a bit on what model you have, but for most models you may just be able to connect your Walkman to a computer via USB and you should find your music in a location such as: My Computer\WALKMAN\Storage Media\MUSIC and then you ought to be able to delete any files you want there.
Hope that helps.
Hi Jim,
Hope that helps.
