Hi, I’ve been using the E394 for a while now and really like. it. However, today I had a problem with it for the first time. When I imported my playlists (I’ve only got two) from iTunes on my Mac, the playlists on the Sony do not have all the same songs in. The title is correct and the number of tracks is correct but the songs in the playlists are just random songs from my “all songs” section! Some of the right songs are in there, the first 3, but then it goes totally random! Does anybody know why?
Hey GazzaW0323, an update might be the whole reason for this issue,
I'll wait for you.
I couldn't do it in the end. It says there is an update available every time you open iTunes but when you click on it it just takes you to Apple app store and it's not there! I will just have to use the all songs list.
