I bought a used CD Walkman D-EJ760. When I got it, I noticed, that most of the buttons not working. Only button that worked is the volume buttons, but the volume down sometimes stuck in. What I have the problem is, is the pause button. So this model has a switch to skip tracks, and need to press this switch if I want to pause or play. When I insert a new CD, and press the button to start, it's working. But when I want to pause it, it doesn't work. What in the hell can cause this?
Hey @WebbedApe
I think you need to contact Sony to advise with a service for the device, most probably it's a hardware issue
