The volume of the right ear piece is extremely low compared to the left side, I tried to restarting and resetting but nothing changed.
NOTE: I never used it under water, I just clean it by wipes.
please help!
Did you check if something blocks the sound channel on the left ear piece?
If everything looks fine it might be a technical problem.
yes, I checked it out
Have you also tried updating it to the latest software version?
