Hi, I've just removed the ear buds in order to complete the unpleasant task of clearing out any earwax. However the thingy bits that go in the ears are plugged with foam rubber. Is this how they should be or should it have been removed .
Many thanks
This is how it should be. Please do not remove the foam rubber.
Hi Peter,
Many thanks for the advice
Rgds. Dave
