I have a pair of Sony MDR-ZX770BN Bluetooth wireless headphones. How can I use them with my Sony Bravia TV.
The TV has USB ports and a 3.5mm headphone port. I think I can use a plug in Bluetooth transmitter but I'm not sure what type.
Any recommendations appreciated
Hi there
Have a read of this thread:
https://community.sony.co.uk/t5/android-tv/bluetooth-headphones-amp-sony-kd-49x8309c/m-p/2257397
You can connect your Sony Bluetooth headphones with your Sony Bravia TV very easy... you must pick Bluetooth transmitter that would serve your needs, also check the quality and the latency of the transmitter else you may have to compromise at your pleasure time. Usually transmitters with low latency results in breaking or lag between the sound that you hear and the lip sync. Besides that, important factors is picking the best wireless headphones for tv. It's very important to choose the suited wireless headphone for your needs, e.g., Keeping in mind about the type, battery life, latency, quality, and pricing.
I need to be able to adapt my Sony Bravia TV so that I can listen to the sound in my Sony Hear on ,3 headphones. I need a Bluetooth dongle
What model is your TV? Maybe it supports Bluetooth headphones by default.
KDL-55W905A
Well done, what is your question and why are you tagging on to a 9 year old thread.
Write your own question......
