Have just bought the NWZ E474 and think I have a dud. It recharges within 20 minutes and plays for about 5 -6 hours maximum Had an E453 before and it was just great. Long battery life and took far longer to charge. Where do I go with this. Any ideas?? Please answer
Message was edited by: pastor2001
Hi pastor2001,
Welcome to Questions and Answers..
If you suspect you have a 'dud' NWZ-E474 then I would suggest you return it to your retailer and ask if they can swap it over for another one..
