I own a Sony MEX-BT3900U. Cannot connect more than one Bluetooth phone. In an attempt to connect the second phone it gets disconnected first phone. In the manually written as can connect up to 9 devices. Is there any solution?
Hi dasky21,
What it means is that you can register up to 9 devices - but not connect all at the same time. I think the idea is that if someone else is using the car who has their own phone for example, they can register their phone without over-writing your phone which would still connect successfully the next time you used the car.
Hope that makes sense?
Hi dasky21,
