I think the IR receiver is faulty, so the remote cant be used to reset the sound bar, so can anyone help with how to rest it from the SA CT380 soundbar itself, thanks
Hi reggie20, are you referring to the HT-CT380? If yes, it is necessary to use the remote control to reset the unit, have you double checked that the controller itself is not faulty?
