I own a NWZ-S765 walkman player. I wonder why it would not support Greek language settings. Any time I add something through my computer it appears Chinese. Since this product is officially represented and marketed in Greece, can anyone tell me if there is some sort of upgrade to include Greek language settings?
Hi disevas and welcome.
This is a user forum - so you will not get an answer here. Have you tried talking to Sony Support?
As you say, Greek is not supported at this time: -
http://pdf.crse.com/manuals/4288581121/ENG/contents/11/09/01/01.html
Anyone?
