Hi....i removed the EU volume cap(before the audio was very very low) at my nwz-e455 with a method that i read in a forum. Now the volume is ok...but the FM frequency is set to 76-90Mhz (JAPAN range) . If i restore
the EU cap, the fm frequency range will change again? It's possible to restore the limit of 85db in the service menu?
Thanks
can you say me also this method because i have the same problem with you. the volume level is too low. thank you very much.
