Is it possible to disable the automatic wear sensor functionality?
I replace the ear pads as they had become uncomfortable after ~6 months, with thicker ones. The issue now is that my ear if further from the sensor so even when I'm wearing the headset, it thinks I am not. Because of this it turns off the NC/AMB modes and sets it to off.
I disabled the automatic power off option in the android app so they do stay powered. But it would be perfect if i could force it to stop changing the NC/AMB mode
Hi, yes, disable both wearing options through the app: https://helpguide.sony.net/mdr/wh1000xm5/v1/en/contents/TP1000534533.html?search=wear%20sensor%20
Hi unfortunately that doesn't seem to work.
I have the both the automatic power off setting and the pause when headphones are taken off, settings turned off. But the ANC/AMB setting still defaults of the off mode when it thinks I'm not wearing the headset
Hi iMarko, I'm afraid that might be directly related to the ear pads that you're using. But you can try resetting and initializing the headset:
https://helpguide.sony.net/mdr/wh1000xm5/v1/en/contents/TP1000541012.html
https://helpguide.sony.net/mdr/wh1000xm5/v1/en/contents/TP1000541013.html
