Does the current range of Walkmen still insert a gap in between songs like on my old NWZ-A818?
It's a bit annoying when listening to something like Dark Side Of The Moon which has tracks which run into each other.
Garry
HI Garry
I had a look into this yesterday (just never posted back) and I went through the specs of the walkmans posted on the Sony site and I cannot see anything to indicate what is called "Gapless Playback". I therefore conclude the following:
My advice is to contact the Sony Sales team (or your nearest Sony Centre) and find out
Cheers Quinnicus, didn't expect you to pop up again!
I'll try the sales dept then.
ATB
Garry
Your Welcome
Its just I have a lot of free time on my hands, bored and have no life
HI @garry71
I did make a quick enquiry (and for other who are interested) - Unfortunately none of Sony's current range of walkmans support gapless playback.
Sorry that this is not the answer you were hoping for.
Cheers Quinnicus, only just saw your reply, I was away on holiday.
I'll have to dig out my old Sony minidisc then, I think that used to play straight through can't remember now! Sounds a bit better than MP3s anyway.
ATB
Garry
Hi Garry,
The NWZ-F886 definitely supports gapless playback. It didn't when I first purchased it (it did with WAV and FLAC but not mp3) but I think a firmware update has allowed mp3 gapless playback to work. It took me by surprise a little!
There have also been updates to Media Go so I don't know if it is one or both of these measures that has caused gapless playback to work.
No more massive WAV files for me...
James
Thanks for the update mowzacakes
Thats great news and I also echo what Jumpsuit said above, thanks for the update
Thanks for the info mowzacakes. I've had a look at it, and it looks quite good, a bit dear though! I've put one in my amazon basket so I can see if the price drops at all. I'll have to re-rip all my CDs to flac or wav if I get it!
Garry
