Hi All, I have a load of Mini Discs, and I would like to put them onto CD's. Is there something I need to buy to convert them. I have a Sony Walkman MZ-R410.
Many Thanks
A1foxxy123
Good Morning Lord_viridis,
Thank you for the link, I will try it out over this weekend.
Many Thanks
A1Foxxy123
@A1Foxxy123, what's the device that recorded the discs? Forgive me for asking but is it a camera or an audio device?
Good Morning HannahEd01, Thanks for the reply. I am trying to transfer my music from Mini Discs to CD's. So the recording device will be a CD recorder.
Many Thanks
A1Foxxy123
Hi HannahEd01, Sorry it's a Sony Mini Disc player MZ-R410.
Many Thanks
A1Foxxy
Hey there,
You might also want to check this one: https://bit.ly/3EY1wvN.
It got some useful information.
Hope it helps.
You're using a old netMD. so no way you can upload digitally your music files.
Only way is to do the old way with real time recording. Plug the output of the md to ur pc audio input.
Press play on the MD & Rec on the computer and...wait ^^
