Will I damage the MEX-BT3700U if I only connect two speakers to it? I can use "fade" to ensure that the volume gain to one set of speakers is reduced to zero.
Hi ekendraed,
Using one pair of speakers only is no problem - you don't really need to worry about the fader position either (as long as it's either centre or towards the speakers you do have) as the unit knows when there are no speakers connected because no load is present on the internal amplifier and no harm can be done.
Hope that helps.
Thank you Drumzman,
Greatly appreciate your comments.
Regards
Ekendra
