just bought a 2002 ford fous and it has a multi stork device, can it be fitted to my CDX-GT50UI???
Hi snowboarderali,
This sort of thing can usually be done, and normally requires two types of adapter cables: one is for the car model you own, and then you need another which is specific to whatever brand of car radio you own.
Try these guys - I would suggest that a phone call to them might not be a bad idea, just to ensure that you do buy the correct combination if there is one for your car and radio.
http://www.connects2.co.uk/c2search.aspx?catID=24
Hope this helps.
Hi snowboarderali,
Hope this helps.
