I have just bought a new car that has been fitted with a CDX-F7750S head unit and CDX 65 disc changer, it has the rotary commander fitted too.
I put a cd in and it plays finem but won't eject when I press the button. With the disc in and playing the ejext button will change tracks and not playing, changes radio stations. The only thing it seems unable to do is eject the disc!
I have tried pressing the reset button, but it makes no difference.
Trying to get the system to select the multichanger results in a 'press the reset button' message. Yet again, I have done this, but no change other than wiping all the settings on the unit!
Please help, because I'm getting frustrated listening to the same disc!
Thanks
John
