Am I the only one disappointed with the XM4s? Mine seem tighter and hotter on my ears than the xm3s. Every time I put them on after a couple of minutes they switch themselves to ambient sound mode. Even though I have set them not to switch off when removed they still do so occasionally. Also they do not keep constant volume.
Do you have the latest software version installed on the headset? I believe it was 2.0.6 and you should also make sure you have the latest version of the app.
