Полностью удалено из за восстановления системы Windows 10 VAIO, как восстановить VAIO если на сайте есть ПО svt1312z1r и нет ПО к моеиу ноуту svt1312z1rs ? Как быть?
CPUID HWMonitor Report
Binaries
HWMonitor version 1.2.8.0
Monitoring
Mainboard Model VAIO (0x0000012F - 0x00003158)
LPCIO
Hardware Monitors
Hardware monitor ACPI
Temperature 0 53°C (127°F) [0xCBE] (TZS0)
Temperature 1 44°C (111°F) [0xC64] (TZS1)
Hardware monitor Battery
Voltage 0 12.10 Volts [0x2F47] (Current Voltage)
Capacity 0 44950 mWh [0xAF96] (Designed Capacity)
Capacity 1 39610 mWh [0x9ABA] (Full Charge Capacity)
Capacity 2 31350 mWh [0x7A76] (Current Capacity)
Level 0 12 pc [0x58] (Wear Level)
Level 1 79 pc [0x4F] (Charge Level)
Hardware monitor Intel I/O
Clock Speed 0 349.17 MHz [0x15D] (Graphics)
Processors
Number of processors 1
Number of threads 4
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Thread 1 1
-- Core 1
-- Thread 0 2
-- Thread 1 3
Timers
ACPI timer 3.580 MHz
HPET timer 14.318 MHz
Perf timer 2.338 MHz
Sys timer 1.000 KHz
Processors Information
Processor 1 ID = 0
Number of cores 2 (max 😎
Number of threads 4 (max 16)
Name Intel Core i7 3517U
Codename Ivy Bridge
Specification Intel(R) Core(TM) i7-3517U CPU @ 1.90GHz
Package (platform ID) Socket 1023 FCBGA (0x4)
CPUID 6.A.9
Extended CPUID 6.3A
Core Stepping E1/L1
Technology 22 nm
TDP Limit 17.0 Watts
Tjmax 105.0 °C
Core Speed 1396.7 MHz
Multiplier x Bus Speed 14.0 x 99.8 MHz
Stock frequency 1900 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 2 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 4 MBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
Turbo Mode supported, enabled
Max non-turbo ratio 24x
Max turbo ratio 30x
Max efficiency ratio 8x
O/C bins none
Ratio 1 core 30x
Ratio 2 cores 28x
Ratio 3 cores 28x
Ratio 4 cores 28x
TSC 2394.5 MHz
APERF 2457.2 MHz
MPERF 2390.2 MHz
Temperature 0 52°C (125°F) [0x35] (Core #0)
Temperature 1 53°C (127°F) [0x34] (Package)
Power 0 3.56 W (Package)
Power 1 1.20 W (IA Cores)
Power 2 0.04 W (GT)
Power 3 2.32 W (Uncore)
Voltage 0 0.87 Volts (VID)
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01020101h
Max CPUID level 0000000Dh
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 32 KB, 2 thread(s)
Cache descriptor Level 2, U, 256 KB, 2 thread(s)
Cache descriptor Level 3, U, 4 MB, 16 thread(s)
CPUID
0x00000000 0x0000000D 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x000306A9 0x00100800 0x7FBAE3BF 0xBFEBFBFF
0x00000002 0x76035A01 0x00F0B2FF 0x00000000 0x00CA0000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x1C004121 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004122 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004143 0x01C0003F 0x000001FF 0x00000000
0x00000004 0x1C03C163 0x03C0003F 0x00000FFF 0x00000006
0x00000005 0x00000040 0x00000040 0x00000003 0x00021120
0x00000006 0x00000077 0x00000002 0x00000009 0x00000000
0x00000007 0x00000000 0x00000281 0x00000000 0x00000000
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x07300403 0x00000000 0x00000000 0x00000603
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000000
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000000
0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000007 0x00000340 0x00000340 0x00000000
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000001 0x28100800
0x80000002 0x20202020 0x49202020 0x6C65746E 0x20295228
0x80000003 0x65726F43 0x294D5428 0x2D376920 0x37313533
0x80000004 0x50432055 0x20402055 0x30392E31 0x007A4847
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x01006040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000100
0x80000008 0x00003024 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0x0000003A 0x00000000 0x00000005
MSR 0x000001A0 0x00000000 0x00850089
MSR 0x000000CE 0x00080815 0xE0011800
MSR 0x00000017 0x00100000 0x00000000
MSR 0x00000035 0x00000000 0x00020004
MSR 0x000000C1 0x0000FFFF 0xFFF44423
MSR 0x000000C2 0x00000000 0x00000000
MSR 0x000000C3 0x00000000 0x00000000
MSR 0x000000C4 0x00000000 0x00000000
MSR 0x00000186 0x00000000 0x00000000
MSR 0x00000187 0x00000000 0x00000000
MSR 0x000001AD 0x00000000 0x1C1C1C1E
MSR 0x00000194 0x00000000 0x00110000
MSR 0x0000019A 0x00000000 0x00000008
MSR 0x000001A4 0x00000000 0x00000000
MSR 0x000001FC 0x00000000 0x0014005F
MSR 0x00000601 0x18141494 0x80000380
MSR 0x00000602 0x18141494 0x80000190
MSR 0x00000606 0x00000000 0x000A1003
MSR 0x00000610 0x80008098 0x00DC8098
MSR 0x00000611 0x00000000 0xA0743FA4
MSR 0x00000639 0x00000000 0x43220286
MSR 0x00000641 0x00000000 0x037618B6
MSR 0x00000614 0x00000000 0x00000088
MSR 0x0000019C 0x00000000 0x88350000
MSR 0x000001A2 0x00000000 0x08691200
MSR 0x000001B1 0x00000000 0x88340800
MSR 0x00000198 0x00001AE6 0x00000800
MSR 0x00000199 0x00000000 0x00000800
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 0, Thread ID 1
Type 01020101h
CPUID
0x00000001 0x000306A9 0x01100800 0x7FBAE3BF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000001
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000001
MSR 0x0000001B 0x00000000 0xFEE00800
MSR 0x000000C1 0x0000FFFF 0xFFD72A4F
MSR 0x00000611 0x00000000 0xA07494DD
MSR 0x00000639 0x00000000 0x43223BEF
MSR 0x00000641 0x00000000 0x03761E9C
MSR 0x0000019C 0x00000000 0x88330000
MSR 0x000001B1 0x00000000 0x88330800
MSR 0x00000198 0x00001B38 0x00000800
CPU Thread 2
APIC ID 2
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 01020101h
CPUID
0x00000001 0x000306A9 0x02100800 0x7FBAE3BF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000002
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000002
MSR 0x000000C1 0x0000FFFF 0xFFD7417E
MSR 0x00000611 0x00000000 0xA074E63B
MSR 0x00000639 0x00000000 0x432271F3
MSR 0x00000641 0x00000000 0x0376242E
MSR 0x0000019C 0x00000000 0x88360000
MSR 0x00000198 0x00001ABD 0x00000800
CPU Thread 3
APIC ID 3
Topology Processor ID 0, Core ID 1, Thread ID 1
Type 01020101h
CPUID
0x00000001 0x000306A9 0x03100800 0x7FBAE3BF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000003
0x0000000B 0x00000004 0x00000004 0x00000201 0x00000003
MSR 0x000000C1 0x0000FFFF 0xFFF43EEC
MSR 0x00000611 0x00000000 0xA0753D04
MSR 0x00000639 0x00000000 0x4322ADE4
MSR 0x00000641 0x00000000 0x03762932
MSR 0x0000019C 0x00000000 0x883A0000
MSR 0x00000198 0x00001B0F 0x00000800
Storage
Drive 0
Device Path \\?\scsi#disk&ven_axm14s3-&prod_axm14s3-128gm-b#4&26657069&0&010000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Type Fixed
Name AXM14S3-128GM-B
Capacity 119.2 GB
SMART Support Yes
Drive 1
Device Path \\?\usbstor#disk&ven_storejet&prod_transcend&rev_2aj1#s2huj9azc02800______&0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Type Fixed
Name HDD 1
Capacity 596.2 GB
SMART Support Yes
USB Devices
USB Device Запоминающее устройство для USB, class=0x00, subclass=0x00, vendor=0x174C, product=0x5106
USB Device Generic USB Hub, class=0x09, subclass=0x00, vendor=0x8087, product=0x0024
USB Device USB-устройство ввода, class=0x00, subclass=0x00, vendor=0x04F3, product=0x0018
USB Device Qualcomm Atheros AR3012 Bluetooth(R) Adapter, class=0xE0, subclass=0x01, vendor=0x0489, product=0xE036
USB Device Составное USB устройство, class=0xEF, subclass=0x02, vendor=0x04F2, product=0xB328
USB Device Microsoft Mouse and Keyboard Detection Driver (USB), class=0x00, subclass=0x00, vendor=0x045E, product=0x0745
Graphic APIs
API Intel I/O
Display Adapters
Display adapter 0
Display name \\.\DISPLAY1
Name Intel(R) HD Graphics 4000
Board Manufacturer 0x104D (0x90A8)
PCI device bus 0 (0x0), device 2 (0x2), function 0 (0x0)
Vendor ID 0x8086 (0x104D)
Model ID 0x0166 (0x90A8)
Performance Level 0
Core clock 349.2 MHz
Monitor 0
Model SAMSUNG (Samsung)
ID SAM0902
Serial
Manufacturing Date Week 41, Year 2011
Size 40.2 inches
Max Resolution 1920 x 1080 @ 60 Hz
Horizontal Freq. Range 15-81 kHz
Vertical Freq. Range 24-75 Hz
Max Pixel Clock 230 MHz
Gamma Factor 2.2
Monitor 1
Model ()
ID CMN1341
Serial
Manufacturing Date Week 17, Year 2012
Size 13.0 inches
Max Resolution 1366 x 768 @ 60 Hz
Horizontal Freq. Range 0-0 kHz
Vertical Freq. Range 0-0 Hz
Max Pixel Clock 0 MHz
Gamma Factor 2.2
ACPI
ACPI Tree
_GPE
_L0B
_L09
_L0D
_L01
_L02
_L06
_L13
_PR_
CPU0
_PPC
_PCT
XPSS
SPSS
_PSS
PSDF
_PSD
HPSD
SPSD
HI0_
HC0_
_PDC
_OSC
CPDC
COSC
GCAP
C1LM
C1LH
C3LM
C7SM
C7LM
C6LM
C3LI
C6LI
C7LI
C3ST
C2ST
C1ST
CSTF
_CST
CPU1
HI1_
HC1_
_PDC
_OSC
GCAP
APCT
APPT
_PPC
_PCT
_PSS
_PSD
_CST
CPU2
_PDC
_OSC
GCAP
_PPC
_PCT
_PSS
_PSD
_CST
CPU3
_PDC
_OSC
GCAP
_PPC
_PCT
_PSS
_PSD
_CST
CPU4
_PDC
_OSC
GCAP
_PPC
_PCT
_PSS
_PSD
_CST
CPU5
_PDC
_OSC
GCAP
_PPC
_PCT
_PSS
_PSD
_CST
CPU6
_PDC
_OSC
GCAP
_PPC
_PCT
_PSS
_PSD
_CST
CPU7
_PDC
_OSC
GCAP
_PPC
_PCT
_PSS
_PSD
_CST
PPMT
PGRV
ACRT
APSV
AAC0
CPID
CPPC
CCTP
CLVL
CBMI
PL10
PL20
PLW0
CTC0
TAR0
PPC0
PL11
PL21
PLW1
CTC1
TAR1
PPC1
PL12
PL22
PLW2
CTC2
TAR2
PPC2
_SB_
PRSA
PRSB
PRSC
PRSD
PRSE
PRSF
PRSG
PRSH
PCI0
_HID
_CID
_ADR
_BBN
_UID
PR00
AR00
_PRT
HBUS
EPEN
EPBR
MHEN
MHBR
GCLK
D0EN
PXEN
PXSZ
PXBR
DIEN
DIBR
MEBR
PM0H
PM1L
PM1H
PM2L
PM2H
PM3L
PM3H
PM4L
PM4H
PM5L
PM5H
PM6L
PM6H
TUUD
TLUD
HTSE
MCHT
BUF0
_CRS
GUID
SUPP
CTRL
XCNT
_OSC
P0P1
_ADR
_PRW
PR04
AR04
_PRT
LPCB
_ADR
LPC1
LPC0
IOD0
IOD1
RAEN
RCBA
DMAC
_HID
_CRS
FWHD
_HID
_CRS
HPET
_HID
_UID
BUF0
_STA
_CRS
IPIC
_HID
_CRS
MATH
_HID
_CRS
LDRC
_HID
_UID
_CRS
RTC_
_HID
_CRS
TIMR
_HID
_CRS
CWDT
_HID
_CID
BUF0
_STA
_CRS
EC0_
_HID
_GPE
_STA
_CRS
ECO1
PX62
ECO2
PX66
ECMB
RAM_
BNVA
RDEC
WREC
MDEC
_REG
TINI
ECPS
ECWK
KACS
ACST
ADP1
_HID
_PSR
_PCL
_STA
NB0S
NB1S
BSRC
BSFC
BSPE
BSAC
BSVO
BSCM
BSCU
BSTV
BSDC
BSDV
BSSN
BSMN
BSDN
BSCH
GBIF
GBST
B0ST
BAT0
_HID
_UID
_PCL
B0IP
B0SP
_STA
_BIF
_BST
_Q1C
_Q1D
_Q36
_Q40
_Q41
_Q48
_Q4C
_Q4D
_Q50
_Q51
_Q52
_Q53
NTMR
SBNL
SGSW
PSKY
THS0
THS1
THS2
THS3
THS4
THS5
THS6
THS7
KCSS
KCTT
KDTT
KOSD
KVTP
TSP0
TSC0
TSP1
TSC1
KLID
UCLS
_Q2D
_Q2E
_Q2F
KBD0
_HID
_CID
_CRS
PS2M
_HID
_CID
_CRS
SNC_
_HID
SNCD
CIM_
ENCR
ESR_
CMDB
RSTB
CMD0
CMD1
CMD2
CMD3
RSD0
RSD1
RSD2
RSD3
CMB0
CMB1
CMB2
CMB3
RSB0
RSB1
RSB2
RSB3
MXCF
PWAK
WAKR
EAWK
GCIM
SN00
SN01
SN02
SN03
SN04
SN05
SN06
SN07
SNCF
SNCM
S100
S101
S148
S114
S11D
S122
S135
S13F
S15D
S13A
S149
S147
S153
S155
S156
S157
MXBT
GBRT
SBRT
SWSD
_HID
_STA
GVER
GWDP
GWDS
SWDS
_INI
NHPG
NPME
PDRC
_HID
_UID
BUF0
_CRS
GLAN
_ADR
_PRW
EHC1
_ADR
PWKE
PWUC
_PSW
_S3D
_S4D
HUBN
_ADR
PR01
_ADR
_UPC
_PLD
PR11
_ADR
_UPC
_PLD
PR12
_ADR
_UPC
_PLD
PR13
_ADR
_UPC
_PLD
PR14
_ADR
_UPC
_PLD
SDGV
_DSM
PR15
_ADR
_UPC
_PLD
SDGV
_DSM
PR16
_ADR
_UPC
_PLD
SDGV
_DSM
PR17
_ADR
_UPC
_PLD
SDGV
_DSM
PR18
_ADR
_UPC
_PLD
_PRW
EHC2
_ADR
PWKE
PWUC
_PSW
_S3D
_S4D
HUBN
_ADR
PR01
_ADR
_UPC
_PLD
PR11
_ADR
_UPC
_PLD
PR12
_ADR
_UPC
_PLD
SDGV
_DSM
PR13
_ADR
_UPC
WCAM
_ADR
_PLD
_PLD
SDGV
_DSM
PR14
_ADR
_UPC
_PLD
PR15
_ADR
_UPC
_PLD
PR16
_ADR
_UPC
_PLD
_PRW
XHC_
_ADR
XPRT
PMEE
PMES
PR2_
PR2M
PR3_
PR3M
XRST
CUID
POSC
XSEL
ESEL
XWAK
_S3D
_S4D
RHUB
_ADR
HSP1
_ADR
_UPC
_PLD
HSP2
_ADR
_UPC
_PLD
HSP3
_ADR
_UPC
_PLD
HSP4
_ADR
_UPC
_PLD
SSP1
_ADR
_UPC
_PLD
SSP2
_ADR
_UPC
_PLD
SSP3
_ADR
_UPC
_PLD
SSP4
_ADR
_UPC
_PLD
_PRW
HDEF
_ADR
HDAR
DCKA
DCKM
DCKS
PMES
_PRW
RP01
_ADR
PXCS
L0SE
LASX
ABPX
PDCX
PDSX
PSPX
HPEX
PMEX
HPSX
PMSX
PXSX
_ADR
_PRW
HPME
_PRW
PR05
AR05
_PRT
RP02
_ADR
PXCS
L0SE
LASX
ABPX
PDCX
PDSX
PSPX
HPEX
PMEX
HPSX
PMSX
PXSX
_ADR
_PRW
HPME
_PRW
PR06
AR06
_PRT
RP03
_ADR
PXCS
L0SE
LASX
ABPX
PDCX
PDSX
PSPX
HPEX
PMEX
HPSX
PMSX
PXSX
_ADR
_PRW
HPME
_PRW
PR07
AR07
_PRT
RP04
_ADR
PXCS
L0SE
LASX
ABPX
PDCX
PDSX
PSPX
HPEX
PMEX
HPSX
PMSX
PXSX
_ADR
_PRW
HPME
_PRW
PR08
AR08
_PRT
RP05
_ADR
PXCS
L0SE
LASX
ABPX
PDCX
PDSX
PSPX
HPEX
PMEX
HPSX
PMSX
PXSX
_ADR
_PRW
HPME
_PRW
PR09
AR09
_PRT
RP06
_ADR
PXCS
L0SE
LASX
ABPX
PDCX
PDSX
PSPX
HPEX
PMEX
HPSX
PMSX
PXSX
_ADR
_PRW
HPME
_PRW
PR0C
AR0C
_PRT
RP07
_ADR
PXCS
L0SE
LASX
ABPX
PDCX
PDSX
PSPX
HPEX
PMEX
HPSX
PMSX
PXSX
_ADR
_PRW
HPME
_PRW
PR0D
AR0D
_PRT
RP08
_ADR
PXCS
L0SE
LASX
ABPX
PDCX
PDSX
PSPX
HPEX
PMEX
HPSX
PMSX
PXSX
_ADR
_PRW
HPME
_PRW
PR0E
AR0E
_PRT
SAT0
_ADR
PRT4
_ADR
_DSM
SAT1
_ADR
SBUS
_ADR
SMBP
I2CE
SMPB
SBAR
SMBI
HSTS
HCON
HCOM
TXSA
DAT0
DAT1
HBDR
PECR
RXSA
SDAT
SSXB
SRXB
SWRB
SRDB
SWRW
SRDW
SBLW
SBLR
STRT
COMP
KILL
PEG0
_ADR
_PRW
PR0A
AR0A
_PRT
PEGP
_ADR
DGFX
LNKV
_PRW
DGPU
DGID
GDID
_DOS
_DOD
CRT_
_ADR
_DCS
_DGS
_DSS
LCD_
_ADR
_DCS
_DGS
_DSS
TV0_
_ADR
_DCS
_DGS
_DSS
HDMI
_ADR
_DCS
_DGS
_DSS
PEG1
_ADR
_PRW
PR02
AR02
_PRT
PEG2
_ADR
_PRW
PR03
AR03
_PRT
PEG3
_ADR
_PRW
PR0B
AR0B
_PRT
B0D4
_ADR
GFX0
_ADR
PCPC
PAPR
_DOS
_DOD
DD01
_ADR
_DCS
_DGS
_DSS
DD02
_ADR
_DCS
_DGS
_DSS
_BCL
CBNL
_BCM
_BQC
DD03
_ADR
_DCS
_DGS
_DSS
DD04
_ADR
_DCS
_DGS
_DSS
DD05
_ADR
_DCS
_DGS
_DSS
DD06
_ADR
_DCS
_DGS
_DSS
DD07
_ADR
_DCS
_DGS
_DSS
DD08
_ADR
_DCS
_DGS
_DSS
SDDL
CDDS
NDDS
IGDP
GIVD
GUMA
GMFN
ASLE
GSSE
GSSB
GSES
CDVL
LBPC
ASLS
IGDM
SIGN
SIZE
OVER
SVER
VVER
GVER
MBOX
DMOD
DRDY
CSTS
CEVT
DIDL
DDL2
DDL3
DDL4
DDL5
DDL6
DDL7
DDL8
CPDL
CPL2
CPL3
CPL4
CPL5
CPL6
CPL7
CPL8
CADL
CAL2
CAL3
CAL4
CAL5
CAL6
CAL7
CAL8
NADL
NDL2
NDL3
NDL4
NDL5
NDL6
NDL7
NDL8
ASLP
TIDX
CHPD
CLID
CDCK
SXSW
EVTS
CNOT
NRDY
SCIE
GEFC
GXFC
GESF
PARM
DSLP
ARDY
ASLC
TCHE
ALSI
BCLP
PFIT
CBLV
BCLM
CPFM
EPFM
PLUT
PFMB
CCDV
PCFT
GVD1
PHED
BDDC
DBTB
CDCT
SUCC
NVLD
CRIT
NCRT
GSCI
PDRD
PSTS
GNOT
GHDS
GLID
GDCK
PARD
AINT
SCIP
_DSM
NDLC
SNDL
S2ND
SPBR
SBLX
IGPU
IGID
MCHP
TASM
BN00
PARC
PBRC
PCRC
PDRC
PERC
PFRC
PGRC
PHRC
XUSB
LNKA
_HID
_UID
_DIS
_PRS
_CRS
_SRS
_STA
LNKB
_HID
_UID
_DIS
_PRS
_CRS
_SRS
_STA
LNKC
_HID
_UID
_DIS
_PRS
_CRS
_SRS
_STA
LNKD
_HID
_UID
_DIS
_PRS
_CRS
_SRS
_STA
LNKE
_HID
_UID
_DIS
_PRS
_CRS
_SRS
_STA
LNKF
_HID
_UID
_DIS
_PRS
_CRS
_SRS
_STA
LNKG
_HID
_UID
_DIS
_PRS
_CRS
_SRS
_STA
LNKH
_HID
_UID
_DIS
_PRS
_CRS
_SRS
_STA
MEM2
_HID
_UID
CRS1
CRS2
_STA
_CRS
LID0
_HID
_LID
_PSW
_PRW
AMW0
_HID
_UID
WLMP
WMID
B0ED
WLID
B1ED
_WDG
_WED
WQAA
WSAA
WMAB
WMAC
WQDD
PTID
_HID
_CID
IVER
_STA
TSDL
PSDL
OSDL
TSDD
PSDD
OSDD
SDSP
PADA
PADD
PADT
RPMD
WPMD
ISPC
ENPC
RPCS
RPEC
IFFS
FFSN
FFSA
FFSS
FFST
FFSP
_HID
_CID
GFFS
SFFS
GFTV
SFTV
_SI_
_TZ_
TBSE
CRT0
PSV0
TZS0
_TMP
_CRT
_SCP
TZS1
_TMP
_CRT
C2K_
_REV
_OS_
_OSI
_GL_
SS1_
SS2_
SS3_
SS4_
IOST
SP2O
SP1O
IO1B
IO1L
IO2B
IO2L
IO3B
IO3L
SP3O
IO4B
IO4L
MCHB
MCHL
EGPB
EGPL
DMIB
DMIL
IFPB
IFPL
PEBS
PELN
SMBS
SMBL
PBLK
PMBS
PMLN
LVL2
LVL3
LVL4
SMIP
GPBS
GPLN
APCB
APCL
PM30
SRCB
SRCL
HPTB
HPTC
ACPH
ASSB
AOTB
AAXB
DSSP
FHPP
FMBL
FDTP
FUPS
BEL_
BEH_
BRH_
BTF_
BYB_
BWB_
BELC
BRHP
BTFC
BEHP
BELP
BTL_
BTFP
BSR_
BCC_
BEF_
BLLE
BLLC
BLCA
BLLS
BLLP
BLLD
BKF_
BHBE
BHBC
BHBN
BHBM
TCGM
TRTP
WDTE
TRTD
TRTI
GCDD
DSTA
DSLO
DSLC
PITS
SBCS
SALS
LSSS
SOOT
PDBR
DPPB
DPPL
GNVS
OSYS
SMIF
PRM0
PRM1
SCIF
PRM2
PRM3
LCKF
PRM4
PRM5
P80D
LIDS
PWRS
DBGS
THOF
ACT1
ACTT
PSVT
TC1V
TC2V
TSPV
CRTT
DTSE
DTS1
DTS2
DTSF
REVN
RES3
APIC
TCNT
PCP0
PCP1
PPCM
PPMF
C67L
NATP
CMAP
CMBP
LPTP
FDCP
COMA
COMB
SMSC
W381
SMC1
IGDS
TLST
CADL
PADL
CSTE
NSTE
SSTE
NDID
DID1
DID2
DID3
DID4
DID5
KSV0
KSV1
BLCS
BRTL
ALSE
ALAF
LLOW
LHIH
EMAE
EMAP
EMAL
MEFE
DSTS
TPMP
TPME
MORD
TCGP
PPRP
PPRQ
LPPR
GTF0
GTF2
IDEM
GTF1
BID_
PLID
ASLB
IBTT
IPAT
ITVF
ITVM
IPSC
IBLC
IBIA
ISSC
I409
I509
I609
I709
IPCF
IDMS
IF1E
HVCO
NXD1
NXD2
NXD3
NXD4
NXD5
NXD6
NXD7
NXD8
GSMI
PAVP
OSCC
NEXP
SBV1
SBV2
DSEN
GPIC
CTYP
L01C
VFN0
VFN1
VFN2
VFN3
VFN4
NVGA
NVHA
AMDA
DID6
DID7
DID8
EBAS
CPSP
EECP
EVCP
XBAS
OBS1
OBS2
OBS3
OBS4
OBS5
OBS6
OBS7
OBS8
ATMC
PTMC
ATRA
PTRA
PNHM
TBAB
TBAH
RTIP
TSOD
ATPC
PTPC
PFLV
BREV
SGMD
SGFL
PWOK
HLRS
DSEL
ESEL
PSEL
PWEN
PRST
MXD1
MXD2
MXD3
MXD4
MXD5
MXD6
MXD7
MXD8
GBAS
SGGP
ALFP
IMON
PDTS
PKGA
PAMT
AC0F
AC1F
DTS3
DTS4
XHCI
XHPM
XTUB
XTUS
XMPB
LPMV
DDRF
MM64
CCMD
COMD
LPT1
PSTP
WKMD
IDER
PIE0
PIE1
CSTS
PMEE
WOLE
NVAD
PGVI
OPTF
IFSE
AOAC
S1C0
S1C1
S2C0
S2C1
SLPS
ALAT
OGNS
OG00
OG01
OG02
OG03
OG04
OG05
OG06
OG07
OG08
OG09
OG10
ECON
MUTX
PRT0
P80H
P8XH
SPRT
SSMP
_PIC
_PTS
_WAK
GETB
PNOT
TRAP
PICM
BRTN
IO_T
TRPI
TRP0
IO_D
TRPD
IO_H
TRPH
PMIO
PEWS
GPE3
PMEN
UPRW
GPEC
GPS3
SCIS
GPIO
GU00
GU01
GU02
GU03
GIO0
GIO1
GIO2
GIO3
GL00
GL01
GL02
GP24
GP27
GP28
GB00
GB01
GB02
GB03
GIV0
GIV1
GIV2
GIV3
GU04
GU05
GU06
GU07
GIO4
GIO5
GIO6
GIO7
GL04
GL05
GL06
GL07
GU08
GU09
GU0A
GU0B
GIO8
GIO9
GIOA
GIOB
GL08
GL09
GL0A
GL0B
RCRB
HPAS
HPAE
SATD
SMBD
HDAD
RP1D
RP2D
RP3D
RP4D
RP5D
RP6D
RP7D
RP8D
UP0D
UP1D
UP2D
UP3D
UP4D
UP5D
UP6D
UP7D
UP8D
UP9D
UPAD
UPBD
UPCD
UPDD
GPI0
GDMA
SFLG
SPIO
SDMA
SETT
BUFN
MBUF
MDBG
MDG0
DB2H
DW2H
DD2H
MBGS
SHOW
LINE
MDGC
UP_L
MOVE
NTOC
CNVS
SFUN
SPR0
SPR1
SPR2
WNVA
WNVB
WNVC
WNVD
WFLG
WNVS
WNVI
TSMI
WDBA
SGSD
CDST
NDST
SKUT
MOID
GPUT
PMDP
AF7E
TRPS
MSMI
WSMI
HKEY
LAMN
RBEC
WBEC
MBEC
BCEN
BCVE
SGEN
PSBN
MSGF
B2ED
WH15
BCLP
BRIA
BIAN
_S0_
_S3_
_S4_
_S5_
SSDT
CFGD
PDC0
PDC1
PDC2
PDC3
PDC4
PDC5
PDC6
PDC7
SDTL
Binaries
Monitoring
LPCIO
Hardware Monitors
Processors
Number of threads 4
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Thread 1 1
-- Core 1
-- Thread 0 2
-- Thread 1 3
Timers
Sys timer 1.000 KHz
Processor 1 ID = 0
Codename Ivy Bridge
CPUID 6.A.9
Extended CPUID 6.3A
Core Stepping E1/L1
Technology 22 nm
Tjmax 105.0 °C
FID/VID Control yes
Max turbo ratio 30x
O/C bins none
Ratio 1 core 30x
Ratio 2 cores 28x
Ratio 3 cores 28x
Ratio 4 cores 28x
TSC 2394.5 MHz
APERF 2457.2 MHz
MPERF 2390.2 MHz
Power 2 0.04 W (GT)
Thread dumps
CPU Thread 0
APIC ID 0
Type 01020101h
CPUID
CPU Thread 1
APIC ID 1
Type 01020101h
CPUID
CPU Thread 2
APIC ID 2
Type 01020101h
CPUID
CPU Thread 3
APIC ID 3
Type 01020101h
CPUID
Storage
Drive 0
Type Fixed
Capacity 119.2 GB
SMART Support Yes
Drive 1
Type Fixed
Name HDD 1
Capacity 596.2 GB
SMART Support Yes
USB Devices
Graphic APIs
API Intel I/O
Display Adapters
Display adapter 0
Performance Level 0
Monitor 0
ID SAM0902
Serial
Size 40.2 inches
Gamma Factor 2.2
Monitor 1
Model ()
ID CMN1341
Serial
Size 13.0 inches
Gamma Factor 2.2
ACPI
ACPI Tree
_GPE
_L0B
_L09
_L0D
_L01
_L02
_L06
_L13
_PR_
CPU0
_PPC
_PCT
XPSS
SPSS
_PSS
PSDF
_PSD
HPSD
SPSD
HI0_
HC0_
_PDC
_OSC
CPDC
COSC
GCAP
C1LM
C1LH
C3LM
C7SM
C7LM
C6LM
C3LI
C6LI
C7LI
C3ST
C2ST
C1ST
CSTF
_CST
CPU1
HI1_
HC1_
_PDC
_OSC
GCAP
APCT
APPT
_PPC
_PCT
_PSS
_PSD
_CST
CPU2
_PDC
_OSC
GCAP
_PPC
_PCT
_PSS
_PSD
_CST
CPU3
_PDC
_OSC
GCAP
_PPC
_PCT
_PSS
_PSD
_CST
CPU4
_PDC
_OSC
GCAP
_PPC
_PCT
_PSS
_PSD
_CST
CPU5
_PDC
_OSC
GCAP
_PPC
_PCT
_PSS
_PSD
_CST
CPU6
_PDC
_OSC
GCAP
_PPC
_PCT
_PSS
_PSD
_CST
CPU7
_PDC
_OSC
GCAP
_PPC
_PCT
_PSS
_PSD
_CST
PPMT
PGRV
ACRT
APSV
AAC0
CPID
CPPC
CCTP
CLVL
CBMI
PL10
PL20
PLW0
CTC0
TAR0
PPC0
PL11
PL21
PLW1
CTC1
TAR1
PPC1
PL12
PL22
PLW2
CTC2
TAR2
PPC2
_SB_
PRSA
PRSB
PRSC
PRSD
PRSE
PRSF
PRSG
PRSH
PCI0
_HID
_CID
_ADR
_BBN
_UID
PR00
AR00
_PRT
HBUS
EPEN
EPBR
MHEN
MHBR
GCLK
D0EN
PXEN
PXSZ
PXBR
DIEN
DIBR
MEBR
PM0H
PM1L
PM1H
PM2L
PM2H
PM3L
PM3H
PM4L
PM4H
PM5L
PM5H
PM6L
PM6H
TUUD
TLUD
HTSE
MCHT
BUF0
_CRS
GUID
SUPP
CTRL
XCNT
_OSC
P0P1
_ADR
_PRW
PR04
AR04
_PRT
LPCB
_ADR
LPC1
LPC0
IOD0
IOD1
RAEN
RCBA
DMAC
_HID
_CRS
FWHD
_HID
_CRS
HPET
_HID
_UID
BUF0
_STA
_CRS
IPIC
_HID
_CRS
MATH
_HID
_CRS
LDRC
_HID
_UID
_CRS
RTC_
_HID
_CRS
TIMR
_HID
_CRS
CWDT
_HID
_CID
BUF0
_STA
_CRS
EC0_
_HID
_GPE
_STA
_CRS
ECO1
PX62
ECO2
PX66
ECMB
RAM_
BNVA
RDEC
WREC
MDEC
_REG
TINI
ECPS
ECWK
KACS
ACST
ADP1
_HID
_PSR
_PCL
_STA
NB0S
NB1S
BSRC
BSFC
BSPE
BSAC
BSVO
BSCM
BSCU
BSTV
BSDC
BSDV
BSSN
BSMN
BSDN
BSCH
GBIF
GBST
B0ST
BAT0
_HID
_UID
_PCL
B0IP
B0SP
_STA
_BIF
_BST
_Q1C
_Q1D
_Q36
_Q40
_Q41
_Q48
_Q4C
_Q4D
_Q50
_Q51
_Q52
_Q53
NTMR
SBNL
SGSW
PSKY
THS0
THS1
THS2
THS3
THS4
THS5
THS6
THS7
KCSS
KCTT
KDTT
KOSD
KVTP
TSP0
TSC0
TSP1
TSC1
KLID
UCLS
_Q2D
_Q2E
_Q2F
KBD0
_HID
_CID
_CRS
PS2M
_HID
_CID
_CRS
SNC_
_HID
SNCD
CIM_
ENCR
ESR_
CMDB
RSTB
CMD0
CMD1
CMD2
CMD3
RSD0
RSD1
RSD2
RSD3
CMB0
CMB1
CMB2
CMB3
RSB0
RSB1
RSB2
RSB3
MXCF
PWAK
WAKR
EAWK
GCIM
SN00
SN01
SN02
SN03
SN04
SN05
SN06
SN07
SNCF
SNCM
S100
S101
S148
S114
S11D
S122
S135
S13F
S15D
S13A
S149
S147
S153
S155
S156
S157
MXBT
GBRT
SBRT
SWSD
_HID
_STA
GVER
GWDP
GWDS
SWDS
_INI
NHPG
NPME
PDRC
_HID
_UID
BUF0
_CRS
GLAN
_ADR
_PRW
EHC1
_ADR
PWKE
PWUC
_PSW
_S3D
_S4D
HUBN
_ADR
PR01
_ADR
_UPC
_PLD
PR11
_ADR
_UPC
_PLD
PR12
_ADR
_UPC
_PLD
PR13
_ADR
_UPC
_PLD
PR14
_ADR
_UPC
_PLD
SDGV
_DSM
PR15
_ADR
_UPC
_PLD
SDGV
_DSM
PR16
_ADR
_UPC
_PLD
SDGV
_DSM
PR17
_ADR
_UPC
_PLD
SDGV
_DSM
PR18
_ADR
_UPC
_PLD
_PRW
EHC2
_ADR
PWKE
PWUC
_PSW
_S3D
_S4D
HUBN
_ADR
PR01
_ADR
_UPC
_PLD
PR11
_ADR
_UPC
_PLD
PR12
_ADR
_UPC
_PLD
SDGV
_DSM
PR13
_ADR
_UPC
WCAM
_ADR
_PLD
_PLD
SDGV
_DSM
PR14
_ADR
_UPC
_PLD
PR15
_ADR
_UPC
_PLD
PR16
_ADR
_UPC
_PLD
_PRW
XHC_
_ADR
XPRT
PMEE
PMES
PR2_
PR2M
PR3_
PR3M
XRST
CUID
POSC
XSEL
ESEL
XWAK
_S3D
_S4D
RHUB
_ADR
HSP1
_ADR
_UPC
_PLD
HSP2
_ADR
_UPC
_PLD
HSP3
_ADR
_UPC
_PLD
HSP4
_ADR
_UPC
_PLD
SSP1
_ADR
_UPC
_PLD
SSP2
_ADR
_UPC
_PLD
SSP3
_ADR
_UPC
_PLD
SSP4
_ADR
_UPC
_PLD
_PRW
HDEF
_ADR
HDAR
DCKA
DCKM
DCKS
PMES
_PRW
RP01
_ADR
PXCS
L0SE
LASX
ABPX
PDCX
PDSX
PSPX
HPEX
PMEX
HPSX
PMSX
PXSX
_ADR
_PRW
HPME
_PRW
PR05
AR05
_PRT
RP02
_ADR
PXCS
L0SE
LASX
ABPX
PDCX
PDSX
PSPX
HPEX
PMEX
HPSX
PMSX
PXSX
_ADR
_PRW
HPME
_PRW
PR06
AR06
_PRT
RP03
_ADR
PXCS
L0SE
LASX
ABPX
PDCX
PDSX
PSPX
HPEX
PMEX
HPSX
PMSX
PXSX
_ADR
_PRW
HPME
_PRW
PR07
AR07
_PRT
RP04
_ADR
PXCS
L0SE
LASX
ABPX
PDCX
PDSX
PSPX
HPEX
PMEX
HPSX
PMSX
PXSX
_ADR
_PRW
HPME
_PRW
PR08
AR08
_PRT
RP05
_ADR
PXCS
L0SE
LASX
ABPX
PDCX
PDSX
PSPX
HPEX
PMEX
HPSX
PMSX
PXSX
_ADR
_PRW
HPME
_PRW
PR09
AR09
_PRT
RP06
_ADR
PXCS
L0SE
LASX
ABPX
PDCX
PDSX
PSPX
HPEX
PMEX
HPSX
PMSX
PXSX
_ADR
_PRW
HPME
_PRW
PR0C
AR0C
_PRT
RP07
_ADR
PXCS
L0SE
LASX
ABPX
PDCX
PDSX
PSPX
HPEX
PMEX
HPSX
PMSX
PXSX
_ADR
_PRW
HPME
_PRW
PR0D
AR0D
_PRT
RP08
_ADR
PXCS
L0SE
LASX
ABPX
PDCX
PDSX
PSPX
HPEX
PMEX
HPSX
PMSX
PXSX
_ADR
_PRW
HPME
_PRW
PR0E
AR0E
_PRT
SAT0
_ADR
PRT4
_ADR
_DSM
SAT1
_ADR
SBUS
_ADR
SMBP
I2CE
SMPB
SBAR
SMBI
HSTS
HCON
HCOM
TXSA
DAT0
DAT1
HBDR
PECR
RXSA
SDAT
SSXB
SRXB
SWRB
SRDB
SWRW
SRDW
SBLW
SBLR
STRT
COMP
KILL
PEG0
_ADR
_PRW
PR0A
AR0A
_PRT
PEGP
_ADR
DGFX
LNKV
_PRW
DGPU
DGID
GDID
_DOS
_DOD
CRT_
_ADR
_DCS
_DGS
_DSS
LCD_
_ADR
_DCS
_DGS
_DSS
TV0_
_ADR
_DCS
_DGS
_DSS
HDMI
_ADR
_DCS
_DGS
_DSS
PEG1
_ADR
_PRW
PR02
AR02
_PRT
PEG2
_ADR
_PRW
PR03
AR03
_PRT
PEG3
_ADR
_PRW
PR0B
AR0B
_PRT
B0D4
_ADR
GFX0
_ADR
PCPC
PAPR
_DOS
_DOD
DD01
_ADR
_DCS
_DGS
_DSS
DD02
_ADR
_DCS
_DGS
_DSS
_BCL
CBNL
_BCM
_BQC
DD03
_ADR
_DCS
_DGS
_DSS
DD04
_ADR
_DCS
_DGS
_DSS
DD05
_ADR
_DCS
_DGS
_DSS
DD06
_ADR
_DCS
_DGS
_DSS
DD07
_ADR
_DCS
_DGS
_DSS
DD08
_ADR
_DCS
_DGS
_DSS
SDDL
CDDS
NDDS
IGDP
GIVD
GUMA
GMFN
ASLE
GSSE
GSSB
GSES
CDVL
LBPC
ASLS
IGDM
SIGN
SIZE
OVER
SVER
VVER
GVER
MBOX
DMOD
DRDY
CSTS
CEVT
DIDL
DDL2
DDL3
DDL4
DDL5
DDL6
DDL7
DDL8
CPDL
CPL2
CPL3
CPL4
CPL5
CPL6
CPL7
CPL8
CADL
CAL2
CAL3
CAL4
CAL5
CAL6
CAL7
CAL8
NADL
NDL2
NDL3
NDL4
NDL5
NDL6
NDL7
NDL8
ASLP
TIDX
CHPD
CLID
CDCK
SXSW
EVTS
CNOT
NRDY
SCIE
GEFC
GXFC
GESF
PARM
DSLP
ARDY
ASLC
TCHE
ALSI
BCLP
PFIT
CBLV
BCLM
CPFM
EPFM
PLUT
PFMB
CCDV
PCFT
GVD1
PHED
BDDC
DBTB
CDCT
SUCC
NVLD
CRIT
NCRT
GSCI
PDRD
PSTS
GNOT
GHDS
GLID
GDCK
PARD
AINT
SCIP
_DSM
NDLC
SNDL
S2ND
SPBR
SBLX
IGPU
IGID
MCHP
TASM
BN00
PARC
PBRC
PCRC
PDRC
PERC
PFRC
PGRC
PHRC
XUSB
LNKA
_HID
_UID
_DIS
_PRS
_CRS
_SRS
_STA
LNKB
_HID
_UID
_DIS
_PRS
_CRS
_SRS
_STA
LNKC
_HID
_UID
_DIS
_PRS
_CRS
_SRS
_STA
LNKD
_HID
_UID
_DIS
_PRS
_CRS
_SRS
_STA
LNKE
_HID
_UID
_DIS
_PRS
_CRS
_SRS
_STA
LNKF
_HID
_UID
_DIS
_PRS
_CRS
_SRS
_STA
LNKG
_HID
_UID
_DIS
_PRS
_CRS
_SRS
_STA
LNKH
_HID
_UID
_DIS
_PRS
_CRS
_SRS
_STA
MEM2
_HID
_UID
CRS1
CRS2
_STA
_CRS
LID0
_HID
_LID
_PSW
_PRW
AMW0
_HID
_UID
WLMP
WMID
B0ED
WLID
B1ED
_WDG
_WED
WQAA
WSAA
WMAB
WMAC
WQDD
PTID
_HID
_CID
IVER
_STA
TSDL
PSDL
OSDL
TSDD
PSDD
OSDD
SDSP
PADA
PADD
PADT
RPMD
WPMD
ISPC
ENPC
RPCS
RPEC
IFFS
FFSN
FFSA
FFSS
FFST
FFSP
_HID
_CID
GFFS
SFFS
GFTV
SFTV
_SI_
_TZ_
TBSE
CRT0
PSV0
TZS0
_TMP
_CRT
_SCP
TZS1
_TMP
_CRT
C2K_
_REV
_OS_
_OSI
_GL_
SS1_
SS2_
SS3_
SS4_
IOST
SP2O
SP1O
IO1B
IO1L
IO2B
IO2L
IO3B
IO3L
SP3O
IO4B
IO4L
MCHB
MCHL
EGPB
EGPL
DMIB
DMIL
IFPB
IFPL
PEBS
PELN
SMBS
SMBL
PBLK
PMBS
PMLN
LVL2
LVL3
LVL4
SMIP
GPBS
GPLN
APCB
APCL
PM30
SRCB
SRCL
HPTB
HPTC
ACPH
ASSB
AOTB
AAXB
DSSP
FHPP
FMBL
FDTP
FUPS
BEL_
BEH_
BRH_
BTF_
BYB_
BWB_
BELC
BRHP
BTFC
BEHP
BELP
BTL_
BTFP
BSR_
BCC_
BEF_
BLLE
BLLC
BLCA
BLLS
BLLP
BLLD
BKF_
BHBE
BHBC
BHBN
BHBM
TCGM
TRTP
WDTE
TRTD
TRTI
GCDD
DSTA
DSLO
DSLC
PITS
SBCS
SALS
LSSS
SOOT
PDBR
DPPB
DPPL
GNVS
OSYS
SMIF
PRM0
PRM1
SCIF
PRM2
PRM3
LCKF
PRM4
PRM5
P80D
LIDS
PWRS
DBGS
THOF
ACT1
ACTT
PSVT
TC1V
TC2V
TSPV
CRTT
DTSE
DTS1
DTS2
DTSF
REVN
RES3
APIC
TCNT
PCP0
PCP1
PPCM
PPMF
C67L
NATP
CMAP
CMBP
LPTP
FDCP
COMA
COMB
SMSC
W381
SMC1
IGDS
TLST
CADL
PADL
CSTE
NSTE
SSTE
NDID
DID1
DID2
DID3
DID4
DID5
KSV0
KSV1
BLCS
BRTL
ALSE
ALAF
LLOW
LHIH
EMAE
EMAP
EMAL
MEFE
DSTS
TPMP
TPME
MORD
TCGP
PPRP
PPRQ
LPPR
GTF0
GTF2
IDEM
GTF1
BID_
PLID
ASLB
IBTT
IPAT
ITVF
ITVM
IPSC
IBLC
IBIA
ISSC
I409
I509
I609
I709
IPCF
IDMS
IF1E
HVCO
NXD1
NXD2
NXD3
NXD4
NXD5
NXD6
NXD7
NXD8
GSMI
PAVP
OSCC
NEXP
SBV1
SBV2
DSEN
GPIC
CTYP
L01C
VFN0
VFN1
VFN2
VFN3
VFN4
NVGA
NVHA
AMDA
DID6
DID7
DID8
EBAS
CPSP
EECP
EVCP
XBAS
OBS1
OBS2
OBS3
OBS4
OBS5
OBS6
OBS7
OBS8
ATMC
PTMC
ATRA
PTRA
PNHM
TBAB
TBAH
RTIP
TSOD
ATPC
PTPC
PFLV
BREV
SGMD
SGFL
PWOK
HLRS
DSEL
ESEL
PSEL
PWEN
PRST
MXD1
MXD2
MXD3
MXD4
MXD5
MXD6
MXD7
MXD8
GBAS
SGGP
ALFP
IMON
PDTS
PKGA
PAMT
AC0F
AC1F
DTS3
DTS4
XHCI
XHPM
XTUB
XTUS
XMPB
LPMV
DDRF
MM64
CCMD
COMD
LPT1
PSTP
WKMD
IDER
PIE0
PIE1
CSTS
PMEE
WOLE
NVAD
PGVI
OPTF
IFSE
AOAC
S1C0
S1C1
S2C0
S2C1
SLPS
ALAT
OGNS
OG00
OG01
OG02
OG03
OG04
OG05
OG06
OG07
OG08
OG09
OG10
ECON
MUTX
PRT0
P80H
P8XH
SPRT
SSMP
_PIC
_PTS
_WAK
GETB
PNOT
TRAP
PICM
BRTN
IO_T
TRPI
TRP0
IO_D
TRPD
IO_H
TRPH
PMIO
PEWS
GPE3
PMEN
UPRW
GPEC
GPS3
SCIS
GPIO
GU00
GU01
GU02
GU03
GIO0
GIO1
GIO2
GIO3
GL00
GL01
GL02
GP24
GP27
GP28
GB00
GB01
GB02
GB03
GIV0
GIV1
GIV2
GIV3
GU04
GU05
GU06
GU07
GIO4
GIO5
GIO6
GIO7
GL04
GL05
GL06
GL07
GU08
GU09
GU0A
GU0B
GIO8
GIO9
GIOA
GIOB
GL08
GL09
GL0A
GL0B
RCRB
HPAS
HPAE
SATD
SMBD
HDAD
RP1D
RP2D
RP3D
RP4D
RP5D
RP6D
RP7D
RP8D
UP0D
UP1D
UP2D
UP3D
UP4D
UP5D
UP6D
UP7D
UP8D
UP9D
UPAD
UPBD
UPCD
UPDD
GPI0
GDMA
SFLG
SPIO
SDMA
SETT
BUFN
MBUF
MDBG
MDG0
DB2H
DW2H
DD2H
MBGS
SHOW
LINE
MDGC
UP_L
MOVE
NTOC
CNVS
SFUN
SPR0
SPR1
SPR2
WNVA
WNVB
WNVC
WNVD
WFLG
WNVS
WNVI
TSMI
WDBA
SGSD
CDST
NDST
SKUT
MOID
GPUT
PMDP
AF7E
TRPS
MSMI
WSMI
HKEY
LAMN
RBEC
WBEC
MBEC
BCEN
BCVE
SGEN
PSBN
MSGF
B2ED
WH15
BCLP
BRIA
BIAN
_S0_
_S3_
_S4_
_S5_
SSDT
CFGD
PDC0
PDC1
PDC2
PDC3
PDC4
PDC5
PDC6
PDC7
SDTL
Извиняюсь, неправильно вставил отчет о HWMonitor , как то не получилось у меня.
Отредактированно кактусом:smileycat:
Это Ваш КАМЕНЬ:
http://ark.intel.com/ru/products/65714/Intel-Core-i7-3517U-Processor-4M-Cache-up-to-3_00-GHz
Камень core i7 3517U и Технология Intel® Turbo Boost ‡ 2.0
Работоспособна
И поверьте она лучше нас знает что надо камню и какие нужно держать обороты кулера.
Всего наилучшего
Добрый День! Большое спасибо за ответы. Значит все будет работать хорошо ? Без перегрева и тп.? Акумулятор переставил как Вы сказали - действительно , теперь заряжается до 100% и делает расчет времени. Большое спасибо!
Mishagood Значит все будет работать хорошо? Так он так и работает.
Без перегрева и тп.?:smileyshhh:
Алло Mishagood мечтать не вредно.:smileyrose:
Без перегрева это если у Вас имется возможность купить это:
Если не будете таскать по одеялам:smileythumbsup:
Если не гонять дикие игрушки.
Камень у Вас вcего 15W; хоть и имеет имя i7
