Partilhe a sua experiência!
Hello
My brand new VAIO seems to have a problem with the battery and/or the charger.
When using the computer while the battery is charging, the screen often dims for a slip second as the contact with the power source is "broken". I don't know if the problem comes from the battery itself, the charger or even the computer.
Has anyone experienced the same problem? I could really use some guidance here.
It is really anoying!!!
Thank you.
FVZ
Hello
Thank you.
FVZ
