Hi ive bought a vaio z1xsp and its very good apart from the let down of the 16mb graphics card. Does anybody know where I can upgrade this.
The bad news is you can't.
Worldwide there is only one manufacturer that offers notebooks where you can actually upgrade parts as easy as on a desktop. They start at about 5.000 Euro :smileygrin:
What application do you have where that graphic isn't enough?
If bad comes to worse, you can use the following external solution:
VillageTronic
