Well a month ago i was thinking about upgrading my vaio A317S memory to 1G.. i check on sony site and yikes.. very ery expensive.. so i check up crucial.. and yes! its alooooot cheaper! 1x512mb is £50.51 inc vat. so i would need 2x512mb which will cost me £101.2 inc vat. which is still alot cheaper than sony.. but then i think again what if i wanted to upgrade to 2G??? hmm so i put it on hold.. untill
Today!.. i check crucial up again and yes they now had 1x1GB memory haha and it cost £104.56 inc vat which i think is very very good!.. order it and now i am waiting for it to arrive... and hopefully everything will be fine when i install it...
BTW since i bought 1x1GB ram which only use 1 memory slot.. can i leave the 1x256mb (original memory) in the other slot? so i can had 1GB+256MB ram?
The new Firerfox version needs a lot, IMO.
Yesterday it was approx 100MB with 5 open tabs.
Yep, the other thing is, that makes Firefox faster than IE. But I'm sure that IE7 would need similar resources.
Time will tell Seb
Whats on the new firefox, just that security issue been fixed??
Yep
well normally i had about 75++ processes running at one time... hmm about time to upgrade it to 2GB?:smileylaugh:
Thats a lot Eugene
Thats a lot Eugene
auto-updater, spyware, trojans, quick strarter, etc.:smileycool:
