if there are any USB-devices connected to the notebook while starting the notebook, it doesn´t start. Interrupting the connection between notebook and USB device is one possible solution of the problem. Doing so, the machine will start properly.But there might be other ways for solving the problem?
Best regards
HK64
Had this problem with a DeLL, we sorted it out by buying a powered USB hub.
HTH
