OK i was using sonic stage to delete all the songs of my vp vgf-ap1l but my laptop crashed near the end and now i cant transfer any songs onto it
Any ideas whats going on and anyway to get it working again
Any and all help appreciated
Try reseting the VP, if that doesn´t work I think you should need to format/inicialize the unit.
Hope it works,
Ameli
Unfortunately not Thanks anyway i was poking around it and noticed that the OMGAUDIO folder normally has a load of folders within it but now it doesnt could that have anything to do with it
ps - i have the latest firmware and sonic stage
Reinstall SS 3.3, it will find all your files from your HD too so you shouldnt lose anything.
C
still no luck 😞
