can we adjust the volume of SPDIF in the master volume? is anyone have the same machine VGN-A517B could tell me?
Thanks!!!:smileyhappy:
You should be able to
Just click on your speaker icon in the taskbar, go to the menu then properties and click the checkbox next to SPDIF so ti can be shown in the mixer
but mine SPDIF is grey can't move it!!!:smileycry: , just wonder isn't i'm upgrade the optical driver and make it can't move anymore? pls help me, what can i do???
but mine SPDIF is grey can't move it!!! , just wonder isn't i'm upgrade the optical driver and make it can't move anymore? pls help me, what can i do???
I have heard some VAIO users having SPDIF, I know the RA104 does
Thanks for the info Kee-Lo do you know if any Laptops have SPDIF?
Yeah the A series multimedia dock
