Just purchased a SZ71MN/B and cant get the LAN to work. How the hell do you get any one at Sony to talk to you
Hi Mikebutton,
1st welcome to Club VAIO.
About your WiFi issue: 1) ensure switch is turned on and led is indicating turned on, 2) in Windows, wireless switch application is properly selected with 2.4Ghz and enabled. 3) If still NOK, check in device manager if wifi driver is properly installed. 4) ensure you are close your router (let your router in a standard configuration so your computer will detect wireless on 1st attempt).
Otherwise hotline VAIO is 0870 240 2408
Let us know a further feedback. Good luck!
