Hi, my laptop can't detect wireless networks anymore. It simply stopped working and even when I know there is an available network it tells me none can be detected. The switch is at the on position, but the only advice I'm given by my computer is to turn the switch on! Has anyone else had this problem? Can it be fixed easily?
Thanks!
Sam
Hi Englishtoast,
welcome to Club VAIO..
Is wireless LAN enabled in the Wireless Switch utility.?
Unfortunately for some reason I catch attach an image guide but you can find a one HERE
Great, that seems to work! Thanks a lot :smileygrin: !!
You're welcome..
