i just had my PCG-K215Z return to me from sony for having a faulty hard drive, before the hard drive was faulty everything worked fine. The problem I have now it that the 215z will not connect to the internet through the wireless connection, iv tryed as much as i know with no joy. Is there something stupid that im doing or does anyone have any hints thank you
Have you tried it with the firewall switched off?
i have tryed it with out the firewalls on both machines, should the laptop detect wireless connections automatically as the machine is technically 1 day old, also when a move the cursor over the internet connection on my task bar(next to the clock) it says wireless connection unavailable, as the router is provern to work and there is some other persons in my street with wifi that i use to beable to connect, i still get to no signal HELP
