Can any one help please. My computer wireless switches itself off after 10 minutes or so. Has anyone experienced the same? if so how do I repair this problem?
Hi Alberto,
Please let us know your model number - hopefully then someone will be able to assist...
Hi Rich
Thr computer model is VGN-FZ11S PCG-381M
Thanks
Alberto
Hi Alberto,
Have you checked whether the wireless device is set to turn off to save power if running on battery? Check the power management tab under properties in Device manager.
You could also try attaching an Ethernet cable between the router and notebook to see whether the same problem occurs.
Also, have you eliminated the router as the cause of the problem?
Rich
