Hi community
My 7+ year old VPCCW2S1EL has a wireless switch (a physical switch on the right side of the laptop's front), and this switch seems to no longer work. When it worked, I could move the switch from "OFF" to "ON", a light would turn on, and I was able to connect wirelessly to the internet. For about a year the switch has not worked - the light does not come on, and the VAIO Smart Network software does not allow me to connect, but just tells me to turn on the wireless switch, which I cannot do.
If there is some way of overriding the physical switch altogether, please let me know.
Regards
K
VAIO Veteran
Hi K and welcome
There doesn't appear to anyone with a similar problem or solution, so you may be better asking the Sony Support team if they are able to help.
Hope you find a fix.
Mick
