I have just bought a vaio FS(z) and I am having problems with the wireless connection. It disconects and then automatically aquires a network address. It's a bit of a pain especially when downloading as when it is re aquiring the network address it disconnects from the internet. Anyone help!!!!!:smileycry:
did you try installing the Intel driver for this particular wireless chipset? You can find it on http://support.intel.com/support/wireless/wlan/sb/CS-010623.htm[/url]
Thanks for letting me if it works for ya.
Cheers for the reply. I have been trying things all day and so far so good, I forced an IP address via tcp/ip and disabled the dchp on the router. If this fails will download from the intel site.
Many thanks
Firewall issue perhaps
