can anyone help
i have just installed a 2200b/g wireless minipci card into my grs515m
the problem is it keeps telling me to enable my hardware switch which does not exist on this model as far as i can tell
anyone got any solutions please??
We are talking a physical switch and not a software switch?
My TR5 has both but the physical switch turns on both bluetooth and wireless, so there is a software option for enabling only one or both.
Assuming your laptop had the right connection for a wireless card it would follow that another model with the same motherboard had wireless capability as standard.
My only suggestion would be to search out this model and try to find out where this switch attaches to the mobo. If its a simple two wire connection (which I doubt as its probably integrated into a circuit board and linked by a common ribbon cable.) you could "jumper" the connection and leave it permanently on.
Unless you can do that I am sorry to say I don't think you can ever use it.
I hope I am wrong
People on the TR5 Forum routinely upgrade their elderly slow TR1 wireless cards in the same way as you but they already have an existing hardware switch.
PS One possible solution! If you can see where another model has the switch you may find the underlying circuit board on yours has a vacant area where a switch would reside. This may offer you a solution by bridging the correct contacts to simulate an ON position.
thanks mate
cant figure out what the wireless model of this machine is but i will take a look at m/b see if anything makes sense
You may find this place helpful regarding parts diagrams,
NEXTTRONICS
They are american model numbers which are different, but they had a much wider range of GRS models which may be the answer.
Unfortunately the site seems to be down when I looked.
i found a similar model the grs600
found where the switch is mounted externally but no reference to motherboard
you wouldnt happen to know where i could get my hands on the m/b manual do you
its not looking good at moment
The link in my earlier post is the only place I know with parts diagrams.
Try this other .LINK
The front door doesn't work but this way does!
The GRS 300 has a switch in the front panel (No 11). It seems to function with PWB (No41). I think No 41 is a PCB with all the little front lights on. This seems to be the board that the switch is mounted on.
Hope it works out for you..
