I am getting a Wireless networking for my Xmas this year. I just want to know can i install a Wireless PCI Card with my Sony VAIO RZ422P? so that i can use Wireless networking with my Custom made Pc in the hall. I'm getting Belkin Networking kit the PCU card is:-
Belkin 54MB Wireless Desktop PCI Network Card
Can i open the case up and replace it with this PCI Card? I also getting the PS2 and Xbox and custom PC and my laptop all Wireless (G mode). I just want to know if i can put a PCI Card in the VAIO Machine??
Yes that should be no problem.
Make sure you earth youself by touching a radiator
hi i haven,t done this myself but if you go to control panel - netwok and internet connections there is a wireless network set-up wizard it might help
U Sure? So can u show me what my motherbroad is like?
There's a spare PCI slot in there Danny.
It's a long white socket.
They look like this:
Belkin has its own wireless networking monitor, but if you have windows XP SP2, then let windows do it, else they both clash!
I have an RZ502P which is probably similar and there was at least one spare PCI socket available which enabled me to fit a wireless PCI card and have it up and running in a few minutes.
William
There's one in the RA104.
Akanksha: with Microsoft's track record I know I'd stick with Belkin
Al keep u guys up to date with whats gonna happen. What wireless are all ur guys on with. I have a Linksys Wired Router BEFRS41. Should i just get an access point?
