Hi all,
I am new here and relativly new to PC's in general. I have recently purchased a Vaio PCVRS346 with the room link kit. I would like to set it up to work wireless. Can anyone please tell me what PC card and other bits I need to achieve this.
Hope you can help.
Thanks
Simon
You will have to supply more information: How many computers do you want to network? Do you use broadband and do you want to share the connection? What do you want to use the network for?
The more information you can give, the more replies you will get.
At present I only have the one desk PC and a laptop from work. With my PC I was supplied the Sony Room Link kit which connects to the TV/HiFi so I can listen to my mp3's or watch stored video on the TV and record to the gigapocket on the vaio. This is the bit I really want to control via the net work. Otherwise it will be a case of drilling holes and threading cable around the house (as it show cable conections in the room link documentation), so though the wireless aproach would be alot better.
I do not have broadband at present (still using dial up) but hope to change in the very near future.
Have talked to one person that advised me to buy a Belkin PCI card (802.11g standard) and a Linksys wireless-G ADSL gateway (802.11g) standard.
Would this work?
Any more information required?
Simon
You need to use either a wired LAN or an 802.11g network for speed reasons. I have heard that the Belkin card is good quality and should provide you with the speed you need.
If the notebook has an 802.11g network card then you won't need anything else as you can just use an Ad Hoc network setup. If the notebook is 802.11b then you will probably need to buy a PCMCIA 802.11g card for it (again for speed reasons) although the 802.11b card will connect at a slower speed. If the notebook has an 802.11a card then you will need a PCMCIA 802.11g card otherwise it will not connect.
The thing to remember with a wireless network is that the speed of transmission can reduce quite quickly over distance. The number of walls that the signal has to penetrate can also reduce the signal very quickly.
If you want to use the Vaio Media application then it will need to be installed on both computers (Both computers must be Sony).
I would wait for further info from others - Intradink, where are you?
:smileygrin:
What you need is the following. ( I have the same and it works fine)
- TV cable mounted to your PC in cases that you want to record TV. Of course you need also an TV card in your desktop
- the belkin ADSL wireless router will work
- a wireless access point to connect to your roomlink ( I work both with the sony access points, on my desktop and with roomlink)
- I would suggest the 802.11g connection otherwise the quality will be poor and slow
- It is likely that you first must install an ip address on the wireless access point (room link) since you can not install it with your TV. So connect first the wireless access point to your PC for installing the IP address
Configuration:
- Your desktop is the server and is connected to the ADSL router
- Laptop connected to the ADSL router
- Internet connection the same
- sharing of internet is not needed since every PC has its own connection
- start media server and check if access from other devices is permitted
- then ask authorization for every device, so desktop, pc and roomlink
- It is advisable to disconnect temporary the firewall on the desktop and laptop. Check also if in the ADSL router a firewall is included.
- I needed to figure this out myself since the Sony manual is really poor.
This should work,
Good luck
Jeroen
Sorry.... missed this one. :smileyblush: Dear Intradink,
If you want a wireless connection between the desktop and roomlink, you should also connect a wireless device to roomlink. This can be either an accesspoint or a traditional wireless transmitter. Both will work.
Jeroen
OK... I understand. As I said, I don't know about RoomLink. Just had a quick look on the internet for a RoomLink review and found this.
$200 ! Is it any good?
Hi thanks for your comments and help.
I went out and bought a Belkin wireless PCI card and a US Robotics Turbo Access Point/Router.
Trouble i have now is getting the two things to actually talk to each other. I thought it would just be a case of when i turn on the pc the pci card would realise that it could send a signal to the router. However it can take up to 20mins for a link to be created...
This is a nightmare but can not wait to get it working so i can use the sony media center/room link or what ever it is called to its full potential.
So again is there any advice. What am i doing wrong other than never learning about PC's when I was at school!!!!
IS it some thing to do with having to tell the router my IP address I think I read that somewhere in the manual?
OK... this is a little more difficult as the setup is usually dependant on the specific hardware.
Under network connections, check your wifi connection [right click > properties > TCP/IP > click the properties button] and see if they are setup to 'obtain automatically' both options.
If this makes no difference, then use a wired/etherent connection to your router. You should then be able to use internet explorer to configure it by browsing to something like 10.0.0.x or 192.168.0.x [check you documentation]. If there is an option there to enable DHCP etc, then enable it and try the paragraph above again.
