I have a vaio S2XP and want to know if anyone can recommend a good wireless mouse.
You have misunderstood me.:smileycool:
I will not use a Bluetooth mice on my WLAN card. I talking about a WLAN mice. You can buy a WLAN printer, so where is the problem to use a WLAN mice?
I don't see the point Seb.
Why WLAN, you don't need to use a mouse 100m away!
Anyway thats what Bluetooth was made for.
ok dont know how good it is but just thought i mention it as i like gadgets. if they made this for bluetooth even better if not i should think of making one like that if possible.
http://www.a4tech.com/en/media/thecrucible.htm
looks interesting:smileycool: (but the pad is wired and a little bit tiny:smileysad: )
And true, the mouse wheels from A4Tech are much better as from Microsoft and Logitech. (I don't this f****** clicks, if I use the wheel)
Look at the Benq wireless mouse. The best I've used. The receiver stores inside the mouse when not in use and this switches the mouse off to conserve power. Nice spring-loaded action to eject it to plug into USB. A click the other side releases the battery section. A brilliant design and the right size.
A, cool, thank's. I have looked.
Sounds cool
do I need to use the receiver with my wireless S2XP
Yes. Since it's no bluetooth mouse you'll need the receiver. IMHO a deal-breaker on a BT-enabled laptop.
