hi, i'm trying to connect my rc-103 to a netgear wireless adsl router. Its working fine when attached via cable. I'm trying to figure out weather i need to buy a wireless pc card to get wireless internet or as it comes with a wireless media reciever (yet to be set up) that it would already have a reciever capable of connecting to the router build in. ?
Hi wessley1 and welcome to Club Vaio.
I am not familiar with your model but as far as I can tell from the specs it does not have wireless LAN built in. In which case you will need either a PCMCIA wireless card or a USB wireless adaptor.
sorry, a good start with a slip of the one finger i use for typing.. its an rc-102.. but no matter you've answered my question.. i'l go buy a pcima card in the morning.. thanks for the quick reply. i guess i'll be back soon with questions on how to set up the media reciever,, untill then.. thanks again.
Or if you're brave you could use a PCI card
