i am trying to install the wireless driver from sony's website onto my laptop. i have downloaded it and opened the file there is two files which i can right click and click install on.when i have done this it asks me if i want to open the file i click open then i get a message saying:
the inf file you selected does not support this method of installation.
i am downloaing the file from this link:
http://www.vaio-link.com/downloads/info/info.asp?site=voe_en_GB_cons&url=Vaio/Original/Wireless%20LA...
i have a vgn-nr31j/s
i do not know what to.
if you want you can email direct at [email protected]
thanks
callum
Hi Callum.
Welcome to Club Vaio.
You will need to install the driver from Device Manager.
1. Find the wireless device in Network Adapters in Device Manager and double-click on it.
2. Go to Driver tab and select Update Driver.
3. Select Browse my computer for driver software.
4. Select Let me pick from a list of device drivers on my computer.
5. Select Have Disk....
6. Select Browse....
7. Browse to your back-up driver .inf file (\\netathr.INF) wherever you have it stored.
8. Next ..........
9. If you get a warning screen, select "Install Anyway".
10. Close & Re-Boot
Good Luck
hi thanks for the reply
i have tried the suggestion and it did not work i had to roll back the driver to get it to work again. the software which was on the laptop twhen i brought it did not install. something did install but it did not work.
do you have any other suggestions?
thanks
callum
