I'm very happy with my new S1HP except for one thing:
Wireless LAN (Intel PRO Wireless 2200BG) is corrupting all data sent/received. I've installed new drivers, older ones back, but no luck.
I've tried 7 acces points at freinds, family and so on, but at all places data is corrupted. Wired connections is good, no problem at all.
It's frustrating to have webpages loaded over 5 times to get them right displayed. For those who are interested in a screenshot: http://webmaster.norbertijnenhierden.nl/linksys-prblm.jpg
No matter what I use for encryption, the problem still persists.
I wanted to take out the mini-PCI card and put it back in, but I can't get the antenna connector of the card.
Any suggestions about above problems?
That's certainly unusual isn't it. Logic says if the software isn't doing it then the card is. Best thing to do is get on the phone to support.
Got it working somehow yesterday. I saw I wasn't using older drivers, probably Windows liked the newer ones better.
Unfortunately, I'm unable to use the WPA PSK AES encryption. Only future releases from Intel will support it.
Oh well good on ya. Thanks for coming back and posting the solution/
