Sony vaio has been working via wireless connection fine for months. Now although the switch is still in the on position the wifi light is not illuminated and when I search for networks none can be found. PC states wireless is not on. How can I fix this
Is the software switch turned on? This will either be in the Wireless Switch Setting Utility or in Vaio Smart Network. This depends on which model you have - if you need further help, please give us your Vaio model.
