Can I buy a wireless card for my VGC-RA 304 CEK and any reccomendations would be appreciated.
Hi Derek,
Does not the RA-Series come with a USB Wireless Access Point in the box? You would need this to connect to the MR100 network media reciever.
I could be wrong - so you have three choices of wireless network card:
1. A PCI Internal Card that fits inside your RA-Series.
2. A PCMCIA Card that will fit in your PC Card slot.
3. A USB DONGLE that fits in one of your USB ports.
Thanks a lot for your help and information.
If you can go for #1, but if you can't then go for #2.
I'd avoid #3 if you can as they're not as good.
