Hi all! I'm just downgrade vista to XP on my FZ21S and now i can't find WINDVD BD player, any links for that? thanks.
Hi ds_uk_
Unfortunately, WinDVD BD is not available for download and cannot be reinstalled from your recovery discs. The only possible way to get it back is to carry out a Full System Recovery and this would reinstall Vista.
If you must have XP, you will have to buy a retail copy of WinDVD BD or PowerDVD Ultra to use Blu-Ray.
Hi ds_uk_
There are three versions of WinDVD 9 - Standard, Plus and Blu-Ray.
You will need Corel® WinDVD® 9 Plus Blu-ray.
http://www.corel.com/servlet/Satellite/gb/en/Product/1203568929625
