I have reinstalled my computer many times ... as i usually do with my pc's ... and now i have an error
... with activation.
I'm afraid you will have to phone Microsoft to activate your product. They are very secretive about how many times you can reinstall with a single key. They will ask a few questions to satisfy themselves that you only have this key on ONE machine and why you have installed the system so many times.
If the key is genuine and you only have it on one computer, I'm sure they will activate over the telephone.
You can also get this message if you have changed the motherboard or processor as the activation process thinks you are installing it on a second machine.
As you have nothing to hide, give them a ring. If you cant find the freephone number just click on Start -> Run and type in: -
oobe/msoobe /a
this will bring up the screen you posted above.
thanks
i already thought that i should find a crack ... if there is any
... for mce ... (dont know i always own my win :)) ... but thanks
i phoned them ... its 2:35AM here and they didnt answer ... thats a suprise. coders and helpers are sleeping also. anyway ... ill try to phone them on a working day
Please do not discuss warez, cracking or hacking on this forum, it's an official Sony forum.
You should be able to get a key from MS as long as you explain your case.
sorry ... i have NEVER cracked a win ... and i will never post something related to cracking ... because im a programmer i dont like software stealing so .... i buy my soft as i want my soft to be bought.
No problem, but people can be easily persuided it's a good idea, when it isn't
