Hello there, i got some issues with windows 8 to my Vaio VPCEB1S1E.
I got problem with the Gracphics drivers (is missing OpenGL).
I already contacted with Microsoft and they told to ask the manufacturer for the compatibility of the VAIO to Windows 8...
Thank you for your time
Hi Trelosios,
Sony are not providing support on this model for Windows 8 and it is unlikely that they ever will.
You could try installing the Win 7 graphics driver in compatibility mode but I have no idea whether this will work. Otherwise you need to search for a compatible Windows 8 driver, possibly with a modified INF file, that will install on your notebook.
Rich
