I tried to upgrade my laptop's op-sys from Vista-32bit to Windows7-32bit upgrade. The problem arises with the Nvidia GeForce 8600M GS GPU - driver. Is there a Windows7-32bit driver available or will the Vista-32bit driver work with the new op-sys?
Also how do I get Bluetooth working with Windows7-32bit. When used with Vista-32bit the driver etc. was located at: c:\Program~1\WIDCOMM\BLUETO~1\BTTray.exe.
Thanks for your help/suggestions.
S Mehta
Message was edited by: smehta
