Hi Graham,
As you are able to boot normally by pressing Enter I would first check that there is nothing in either Scheduled Tasks or Startup items (System Configuration) that is causing this.
The other cause is that the Master Boot Record (MBR) has been corrupted. If this is the case then you will need to download a Windows 7 Repair Disk from HERE (assuming that you are using 64 bit OS) and burn the ISO image to DVD.
Then have look at the following link for the repair procedure.
http://support.microsoft.com/kb/927392
Edit: if /FixMbr fails to resolve the problem then use the /FixBoot option.
Rich
Message was edited by: rich912
Hi Graham,
Rich
Hi Rich.
Thankyou for replying.
Forgive me for possibly showing my lack of knowledge, but it appears to me that the above described message appears before any boot-up operation takes place but after any BIOS opps.
What do you think?
Regards
Grahammt
Hi Graham,
As I wasn’t sure exactly how far the boot process progressed after BIOS checks I suggested the actions in the first paragraph of my reply, but I still think that this is a boot issue as BIOS loads the Boot Sector contents from MBR. I recommend trying a repair as detailed in the above Microsoft link.
Rich
Hi Rich.
Followed your advice.
Used /FixMbr and wonder of wonders all is now as it should be:smileyhappy:
Needless to say, I am most grateful for your suggestion.
HUGE regards.
Graham.
Your'e very welcome Graham
