The fan on the computer runs at high speed and a lot of noise most of the time, what is the problem and the solution?
Computer VPCF13M1E
I believe this is a common issue with this specific model
Having googled it there are some solutions that you may want to try out
Do a search on this forum + google and you should find lots of assistance
I have seen a post by a couple other forum members and have posted one of these below
Hope this helps and let us know how you get on
The VPCF11 series had this problem which was addressed by a BIOS Update but I would expect this to have been fixed on newer models.
It may be that processes are running in the background that would cause the fan to provide more cooling - something like the Windows Indexing Service will run for some time with a new Vaio as it indexes the search of the hard drive. Have a look in Task Manager -> Performance to see if the CPU is working on a background process when the fan increases speed.
There is a 'How to troubleshoot fan noise' on the support pages for your model but it may not be the help you need:
If you believe the fan noise is excessive then I would contact Vaio Support and ask their advice.
