HI
I was wondering if anyone could help me. I have just bought a vaio pcg-grt995mp and I am using it to do a lot of internet stuff (I develop internet apps) so I am constantly on the net and I also often use Skype (p2p voip). My problem is that my connection constantly drops out on both the lan and wif i
Is this a known problem or should I send it back to get fixed??
Mike
Guys,
I had a similar problem on the Z1-XMP.
Anyway, the solution to the dodgy WiFi connection is in Device Manager.
Find the wireless card options and change the power setting to max.
That should help of the WiFi connection.
paulo
Mine was at 100% and still the problem persisted. The only way for me to cure the problem was to use the Services selection as above.
Gareth
